WTF!!!!!!
  03 RS clio 172 flameR
ok i was driving home from my girlfiends late saterday night and i was doing about 40 in second gear when the throttle cut out and the brakes automaticlly come on full wack!! i grappled with the wheel to stay in a stright line then quickly pulled over as it felled like my tire blew out, i checked all the tires and they were fine, started it up and drove of fine!
now the only thing i can posiblly think happened is because it was so foggy, moisture got into the ecu, other than that, the people down at renault are trying to kill me!
anyone had there esp go mental on them? keep in mind this was a complely flat road with nothing in the road! its just fucked!
  Megane 2 GT 165
ESP is not TCS actually...
ESP as far as I know does check if the wheels are all making the same RPM. Reducing power to the front wheels when spinning
However there is also a gravity sensor implemented. It measures direction changes and can apply brakes to all wheels individually. Trying to make sure you do not end up in the ditch.
Heard different stories about it, but I only made use of it once, and was NOT dissapointed :D
check out this youtube video.
[youtube]L1qt84c2KN0[/youtube]
Anyway dude you're lucky, and indeed WTF!!! Should get it checked..don't know if they can read out with the CLIP..
i kno yeh lucky isnt the word... WTF is though!
if someone was behind me im pretty sure they would of ended up with there engine in my passenger seat! brakes are pretty mental and that vid makes sence coz it wasnt brakeing all wheels coz it tryed pull me off the road! hense thinking i had a blow out!
wel.... SCREW YOU RENAULT IM STILL ALIVE!!.... il regret that,
  clio sport 182
i was driving down the motorway in my 182 turned to come of the slip road and the steering locked left and brakes went,started up fine after i turned it off and back on again,renault couldnt find a fault
fault?? thats coz its not one! there trying to kills us! trying to write off the clios so we all go out and buy there new one! bet its some nutty manager sitting there strokeing a white cat and doesnt call it writing a car off, its "expireing"
