Xenon headlight level sensor
Hello All,
Please can someone post a pic of the sensor on the rear beam that adjusts the xenon headlight level on a 182?
I've searched for hours on the forum for one to no avale :mad: , but I just need to have a look at one?
As a side note, any idea of a price of one of these from renault?
Cheers guys.
  Clio MkII 172 K reg
This was my thread. At the end I sticked bolt that hold it as clips for almost 4 months already.
part number of the adjuster is 8200078466 and it cost about 125 pounds new. This is Hella make sensor so you can try get it from them.
Cheers For the info!!
Having read a few other threads, is there another sensor on the front axle somewhere thats the same and helps calculated the pitch of the car or is it all done by the one on the back axle, If you get where im coming from?
I know wiring diagrams are a taboo subject but could anyone describe the routing of the of the wires that come from the rear sensor?
Andy
  BMW M135i
Nope only the back sensor for the level adjustment.
Wires run under the body with the rear ABS sensor cables come up into the engine bay to a connector at the bottom rear of the bay in the middle. They then go to each headlight adjuster, the adjusters are powered from inside the car off fuse F3 and ground to the body on either the front left or front right earthing points.
