xenon lights
Do a search on here, fella. There's been a lot of discussion about these. If you were to do what you described and only what you described it would be illegal.
You need the washers for a start, to be legal I mean.
only if fitted from the factory... using the proper 172/182 headlamps it will pass an MOT... they fail if using headlamps that are not designed for xenons...
From what I've read on here that's incorrect. They need washers to be legal and also the self-levelers. Otherwise he's just going to be blinding people all the time.
Correct, you need self leveling and washers. The washers are due to the lights being so bright, and dirt on the lens could break the beam and blind other drivers, and the leveling is for the same thing, so they never blind any oncoming cars
