Xenons ????????
Car  clio 172 cup
Hello peeps. i have a 172 cup and was just wondering if its possible to put xenons onto my car and what would i have to change. thanks
depends who you ask .
you should by the ff 172/182 housing , and balast pack etc.
of you could buy a Hid kit from ricerocketuk on here for about £100 and retro fit your std cup headlights.
The headlights themselves as they're plug and play. However someone will be along shortly to inform you of the legalities of doing this ;)
yes, to do my ph 1 172 it took about 1- 2 hours
which included taking the bumper off and the headlights out etc.
A pair of headlights with all the required gear etc can be had for around £350. Then an hour to fit them, I could even fit them for you.
You'll obviously need a pair of xenon bulbs aswell and two voltage regulators plus the balast as mentioned above
The squirters are only about £10 each from reno then you'll need the extended hoses that run inside the bumper to feed them
Not if he buys those in my link Rich, they're complete (not including the washers obviously).
