Top mounts clunking since fitting camber bolts
Car  RB Clio 182
Hi, i have got clunking from the top mounts ever since fitting my camber bolts.
I have done a search and ive heard something about a washer that needs to be put underneath to stop it, is this correct or do i need new top mounts?
Also, do the the new top mounts come with the spacer to eliminate the knocking? If not, what size washer do i need?
Mine only started to do it after fitting the camber bolts.
Thanks for any help.
I checked the top mount again today after work and it had come loose, it must not have been nipped up tight enough when i had my springs fitted last year :S
I have tightened them both up and the clunking has stopped, happy days thats saved me some brass :D
Thats good! If you need to know about the washer PM me :)
Thanks
Thanks Ethan will do :)
I think thats it sorted now, god knows how it had come loose!
I thought it was buggered because i could spin it, then when i double checked it today i noticed that the nut was spinning too lol.
All torqued up now and as silent as a mouse :)
Those two washers at the top that you put on, can you just undo this bolt and put them on? Don't want my car to shoot up or anything :(
