BMW M3, Clio 172
Hi, I did my second track day with my 172 yesterday at brands since I rebuilt and modified the car. The car was going well but because it was damp and wet yesterday it suffered really bad from under steer that wasn't there before I did the upgrades. I was extremely lucky to win 30 mins tuition with touring car driver Tom Chiltern who was great and taught me how to load the front and make it grip and help turn in and to control oversteer. By the end of the day I was performing some decent controlled slides. He recommend raising the rear or dropping the front of the car.
I have set the car up to have a 15mm rake, measured from the sill, spax springs at lowest settings on rear and the front coil overs wound up to get the 15mm rake.
Damper settings are 10 clicks out of a possible 16 on the stiffer side
2 deg neg camber on front, 1.7 deg neg camber rear (using shims)
0 toe
tyre pressure are 28 front and 26 rear (hot)
Toyo 888's
Pure Motorsport Strut brace and top mounts
fully polybushed
stripped and lightened
Before the upgrades it was running standard worn out suspension, apex lowering springs, 1.5 neg camber front, standard 1.2 neg camber rear, budget tyres and although it didn't have as much overall grip it was was better balanced and inclined to oversteer.
My questions are what should I change first, raise the rear? Drop the front? How low on the front should I go? How important is the 15mm rake? More front camber?(but from what I've read that will make it worse in the wet). Can this be dialled out with damper settings although the spax kit only have rebound damping. I'm not looking for a race car just something to have fun with but the under steer is so frustrating. The car is not road legal and will only be used on track.
here are some photos to compare heights from before and after. Sorry there not the best but all I have.
Any help or advice will be appreciated before I take tom chilterns advice and wind up the rear, thanks.
0 toe
Toyo 888's
fully polybushed
