RSTuner ABS module brake bleed
Has anyone bled their brakes with the RSTuner module?
How did it compare to say using Clip?
Just wondering if it's worth getting for bleeding the brakes 'properly' and activating the ABS pump
Or would it be better just to borrow someone's Clip every so often?
Thoughts and comments from someone that has experienced both options much appreciated :)
  Clio Sport 182
Hi, I have just bought the rsTuner ABS module but can't find any instructions on their site (https://fastchip.nl/manual/) or on here on how to use the bleed option? Is there a link anywhere? Or can anyone tell me how to use it?
Thanks
McGherkin
McPension
I think it's under 'cycle abs pump' or similar, in the abs ecu.
Or alternatively you can just take it to a car park, kick the brake hard enough to trigger the ABS a few times and then re-bleed.
