Standard handbrake which worked fine, I just did it a lot faster than normal and slid off.
Hello Paul,
Ha ha nice one, good result Sunday for you well done, I hope your only doing that on practice lol that place is lethal in those conditions.
Regards Russ.
  FF 182
Ordered some TPI Polarized wheel bolts for it. Already have the brand new locking wheel bolts that i won on ebay for £0.99 :)
welshname
Fitted my missing exhaust clamp replacement. Can no longer see the exhaust hanging down :)
  A special one.
Got my engine cover back from the paint shop.
  Clio 182 and Boxster
Jet wash? Did you removing them? If not how did you get them so clean?
Just soaked them in a solution of warm water and a some Vanish powder for a couple of hours, scrubbing with a nail brush every so often. Didn't completely remove them, just released them from bottom bracket, pulled them out as far as they would go and secured with a clothes peg.
New head unit as wanted DAB and USB,new CS decal.
Is that the pioneer x6600 by any chance? I've just ordered one for my Clio. Any good? Looks nice.
Like the CS stickers! Good choice. Can you upload a pic of the full rear of your car? As I'm looking to fit Rs200 badge soon and don't know wether to leave Clio badge and fit the RS as you have. Or to fit new RS where Clio is. Cheers!
  renault clio 1.4 16v
replaced my sticky hazard light switch and polished the headlights again, planning to put laminex on em to save them from the elements a bit
  FF 182
Midnight
Had it on the ramp so was easy, hardest part was deciding which way the washers go on lol.
On stands, it could be fiddly i guess, if some of the bolts are seized.
Was as this hard too do. Think I'm going to attempt to do it next weekend.
Just depends on what state your old bolts are in. All being well it's a 10 minute job. If you need some strength/heat/sawing/cutting it could take a little longer. A wire brush and some WD40 applied in the days running up to it would help.
pretty easy todo without a ramp, what i done is put a socket on with a ratchet and wedged it in place so it keeps pressure on the bolt then get underneath and add the washer then the spring then the other was plus the bit that sits around the spring then do the nut up fairly tight this will make it a lot easier doing the other one up then. thats how i've done it the last 3-4 times.
  Clio 172
I did my lights today as they were really bad started with them looking like this
Then lots of this
Makes them look like this
I am over the moon with how well they came up.
  Inferno 182
Yes mate it is,£99.99 from halfords and we'll pleased with it. Change colours to suit the dash although I haven't tweaked the brightness yet. I put the DAB antenna on the side window as apparently the sun reflective screens on the Clio can block the signal a bit.
Be warned when you turn it on it says No Signal. Thought it was a DAB fault but you just need to scan through the different groups until it finds some.
Great with the USB as well,using a 32GB sandisk cruzer blade as do not stick out much and loads of music.
Will sort a picture tomorrow.
  225 Cup & Williams
Removed the vibratecnics engine mounts & fitted new oe mount and it feels so much better to drive. Also fitted a cabbasse headunit and ph2 rear clusters on my ph1 172.
  04 Clio 172, Meg 250
Replaced the rear shocks today, can go round corners now without feeling like the back ends going to jump out.
GrahamS
Replaced all my abs rings for the correct tooth.
Started work on the Red DCI as it failed the MOT. Neighbour came out at half 7 and complained I was banging too much at 11:30 this morning and that he hoped I wasn't going to be out late tonight working. He's lived there 2 weeks. I've lived here for 20 years :/
Anyway. I still got 2 ball joints on it replaced with the help of my mildly muted hammer.
