53 plate clio humming when doing 20+ mph
  53Plt Clio 1.6L 16V
Hi there all i have as the title says i have a 53 plate renault clio 1.6L 16v petrol only had it couple months, done 81ish thousand miles and today i have replaced the drivers side wheel bearing and its reduced the humming noise down so its not soo loud but the noise is still there, could it be the passenger side one gona as well ? how ever here is my problem it gets worse when i go round a left handed corner i need some help asap as i need it for work
GrahamS
Jack the car up. Hold the spring and spin the wheel. You'll be able to feel if the bearing is rough in your hand on the spring. Compare it to the wheel with the new bearing
  Megane r26
Or drive down the road, knock it out of gear and gently swerve side to side. Which ever side it gets louder that's the side it is if that makesense
