Leaking into footwell
Car  clio2 2001 1.9dti
Mk2 2001 Got a leak behind the heater unit when it rains. So scuttle off then. What should I be looking for down there, wiper seals worn , missing grommets, is there a usual cause?
Make sure the drain holes are clear and clean, the middle one exits on the centre of the bulkhead in the engine bay at the bottom edge of the insulation and has a rubber flap on the end, make sure it's not blocked down there too. Also worth checking the grommets behind the passenger side wheel arch liner if the leak persists. There's a 'how to' in the guides section iirc
Done it. It was the central drain hole indeed. With the aid of a wire coat hanger opened up, a torch and a neck like an ostrich, I unblocked it. No leaks now
