Fletch's 150k 172 Project..
I took the 172 out a run the other week and on returning I noticed some water on the drive. Under closer inspection she was leaking coolant from a split hose. The coolant hoses are all original so a good excuse to change to some silicone hoses. I also plan on changing the manky expansion tank too.
Untitled by fletcher10, on Flickr
Cleaned the itg air filter too, that was in a right mess so overdue a good wash.
List of jobs..
Buy new silicone coolant hoses and clips probably Samco.
New coolant Expansion bottle.
7 litres of type D coolant.
Oil/ filter change.
Fit new offside driveshaft
Fit new brakes/ discs.
So an expensive month :(
I ordered some parts from Wolverhampton Renault yesterday, they early this morning :)
Nice new coolant bottle.
And the rest of the parts.
I just need to sort out the new coolant hoses now.
I also noticed this morning that I seemed to have broken one of the fuel rail guard bolts :(
My eBay one has been good as gold, I guess its luck of the draw. At least with gen ren ones you'll have price of mind.
Arent forge and SFS hoses cheaper than Samco?
They do coolant tanks at the dreaded Euro for £15, I have on on mine, used the standard top and it looks identical, fits really well and hasn't leaked as of yet :)
I've got a 172 now Fletch so get yours out on track at Goodwood and we'll play follow my leader ;)
Is that Origine RS Matt?
There's no way you'd keep up with the Fletchbus!
Knowsit ;)
Got quite a bit done over the last few days.
New rear number plate light.
Thermostat had been playing up for a bit so changed that. New > Old
I broke a fuel rail guard bolt when removing the fuel rail guard. So that was replaced.
And new forge hoses, not the best pics.
New oil cap. Will fit after next oil change.
url=https://www.flickr.com/photos/fletcher10/14456894928/]
[/url]
The car itself looks quite tired now she's on 144,700 now and never had any paint or dents removed, so overdue some TLC.
Trying to make car more comfortable for longer trips 'Ring etc. I have installed quite a bit of the interior.
I just wish I had done this before the ring trip. I can actually charge devices again with ease and the cup holders are handy for my phone wallet. All the sound deading has been removed so the weight pentally is minimal.
I also cleaned the sabelt wheel it's come up really well condsidering it's age mileage it's done ( forgot to take a pic)
And a photo from yesterday's New Forest run..
I think you've done the right thing tbh. I have the entire lower dash, cup holders, lever surround and handbrake surround still in mine. Had everything flocked when I got the dash done.
I quite fancy getting it flocked eventaully also :)
Will be back to standard before too long.
Good idea though mate. Especially if more long distance track days are in the pipeline.
Yes Chris. I need a bit more comfort now, as I am getting on a bit ;)
Never mind interior trim.. Driveshaft ? Brakes ? Need a catch up, drop me a text.
Brakes need changing now :( I am currently running Compbrake 4 pots these use separate bells rotors, to dissipate heat better .good apart from the disc cost ( you can't run standard discs with them) and they have now gone up to £115 each :eek: last time I needed discs they were £100 each.
So I have decided to go back to the standard calipers keeping my goodridge braided hoses and run some Carbon Lorraine's RC6/ Brembo HC's.
after a clean and some VHT paint
And also today I tried to remove the 4 pots but failed :(
I successfully removed the bell which was also nightmare, and then the top bolt holding the caliper would not budge, so I have given it a good spraying with GT85- WD40. Hopefully I'll get it off after a good 24hrs of it soaking in. If not I will have to drill it out.
