best way to attach cat to cat back on exhaust??
Car  RB182
I currently have a clamp on from the cat to my scorpion cat back but it keeps coming loose and sounding blowen and causing it to drop in the middle. Massive ongoing problem and need sum advice off other 182 owners. Is there a proper fitting kit? Or if I but a straight through on wud that help desperate for a replies plz as its sitting on my drive unusable:evil:
I have a clamp on my 182. going from the cat to my miltek cat back. mine has two nuts on the thread and needs tightening once a year at most.
There must a be a reason why is coming loose? are the threads or nut knackered? take the nuts off and replace them with Nyloc nuts, they won't back off...
Willo
Can you take it off and weld the join? I have done this in the past with annoying exhausts. Janspeed and Ashley mild steel to name a couple but then they were mild and not stainless steel.
I usually get them Sat right, Mark them and then whip them off and get it welded up. Removes options but then it's fit and forget.
i fitted my scorpion 4 years ago and havent touched it since. What clamps are you using?
The genuine Renault one I think jus by comparing it on ebay to the pictures not sure if they are the correct threads and nuts though. Does yours have any support in the middle??
Its been bodged from the garage I bought it from belive it or not the guy called himself a renault specialist lol its been pasted in middle and clamped but its still sounding blowen and coming loose al try the nyloc nuts cheers very helpfull
Think nylocs will melt,try 2 plain nuts locked together with a serrated lock washer.Twin beam nuts,please do a little of research of your own.Dont think you have OE CLAMP,it was a single bolt item,SKU 701458596.
Perhap take a second look,my 172 centre section was totally cracked where pipe went into one of the centre silencers.
