the m9r is a cow bag for that
			You can say what you like...even if the chain gets noisy you can change it before your engine gets trashed...the belt gives no warning. I cannot believe some of the remarks I have read here.
They use belts because they are cheaper to produce and admittedly have the benefit of quieter running...that is all.
Got one coming in, the noise it's making sound like a machine gun going off over the phone. Not looking forward to finding out what it's mashing upthe m9r is a cow bag for that
Rob Barrington, is that you? You're going full Stromba... never go full Stromba!Oh dear...the timing belt in my 1949 Morris Minor may need changing...
1949 Morris minor, push rods, jrwb your showing your age.
did you write to euro car parts?
Is it possible to change the belt to a chain?
...unless you change the pulleys!!
That suggests air...it may leak...the good old chain was so reliable....or push rods with gear to gear contact!
Yes, but at least a noisy chain is not going to mess up your engine
the Ford OHC engine of the late 60s and onwards had a timing belt but did not suffer damage if the belt gave up. I wonder why they do not use this system.
I think the issue comes from the Clio f4r belt being expensive and a nightmare to do.
I've owned a few chain cars with zero issue. The 2.0 zetec unit out the Mondeo and Fiesta ST seems to serve well.
The 3.2 V6 in the Vag range has had a few hiccups, imo for poor servicing.
I also seen an R56 mini chain eat through the casing almost, the car needed a full engine so to speak and it was 12 months out warranty. Iirc her bill was 4.5k.
