Rocker cover Replacement
  Clio 172 PH2
Just had the 172 in for its first service since Ive owned it and the guy said its a solid little car (which is great) but the rocker cover is leaking oil into 2 plugs! Hes not a renault specialist, just a local good garage with a decent reputation.
Would I be better getting this replaced by a specialist or letting him change it? Whats involved with it and roughly how much should I be looking for this to get repaired?
Cub.
It is going to get quite expensive, because when you resealed it, you'll need to redo the cambelt and aux belt. Its circa £300 or so just for all the bits needed for the cambelt / aux belt change iirc. Let alone the labour and the retiming.
In truth, it may be cheaper to buy a decent / healthy engine that has recently had the belts done and sling the whole engine in.
This one for example;
http://www.cliosport.net/forum/show...nt-out-for-169bhp&highlight=rocker+cover+swap
  Clio 172 PH2
It is going to get quite expensive, because when you swap the head, you'll need to redo the cambelt and aux belt. Its circa £300 or so just for all the bits needed for the cambelt / aux belt change iirc. Let alone the cost of a new, decent head, the labour and the retiming.
Cheers for that, I know this is going to sound stubborn but this little fellas only done 70k on a 53 plate with a FSH so id rather stick with it and get it all healthy again! Id say if I could get it all done and healthy and few other tweaks here and there for under a grand id happily keep it. I got the car from someone local who I knew and know it wasnt hammered all its days. I picked it up for an amazingly good price too!
  Clio 172 PH2
Why?
As said wait until cambelt time, or have it all done early if it's causing issues, I don't see why you think you need another rocker cover though?
no issues just a bit spluttery of a morning prior to me knowing, hes changed all the plugs as expected and it seems little better but no doubt itll go spluttery again over the coming days/weeks.
  Clio 172
Because the solenoid seal only takes 20 mins or so to change, I would personally explore this before spending more than I had to, or putting up with spluttering due to soaked plugs.
just an opinion
  172 Ph1/Scooby MY00
Renaultsport Clios all splutter when cold and even sound rough on idle. Take it to a specialist for advice on the leak. It might be ok if you're lucky then wait until the next cam belt change and get it resealed - that's what I did and mine had leaked for a few years.
  Clio 172 PH2
Yeah will do actually I'll just save some monies and get everything done in a oner I guess. Do the guys at SWR have a good reputation?
  172 cup, Impreza P1
Rocker cover is matched to the head I am afraid, so you would need a new head.
Why would you need a new head. Just reseal the rocker cover.
I left mine leaking until the cambelt change was due ( about 18 months ) the car was fine.
This would be my advice too.
It might just be the dephaser solenoid seal, i would try that first
You would see if it's the solenoid seal and it wouldn't leak into the plugs as leads are sealed at the top.
Its due a cambelt change in 18 months or so anyways so is it worthwhile leaving then?
Yup!
Cub.
That's interesting, I'm sure I was told it was a new head required. Clearly not, based on the responses above! Lol!
I've edited the ones above in case someone finds the thread in future....
The cam cover and head is matched, as they are vertically honed as a pair.
I think the OP is talking about removing and re-fitting the cam cover... and not actually replacing it for a different one though.
  172 cup, Impreza P1
Lol, thought I was missing something.
