Can someone sanity check my diagnosis please, before I shell out a wadge of cash I don't need to...
I have a 172 cup on 72k - a while ago it started monkeying about and crunching all the gears, as if the clutch didn't fully disengage. I reset the pedal adjustment and it worked OK.
Started doing it again last week, so I've just replaced the clutch adjuster mech - and it still does the same - however, sometimes when I dip the clutch it feels like it's actually not releasing at all.
I'm thinking either the release bearing or the clutch itself. Before I bit the bullet, is there anything else it could be that doesn't involve taking the box off?
FWIW, it makes a bit of a racket on idle until you dip the clutch, which I guess points even more to a 'you need to get the box off' thing.
And finally, anyone recommend anywhere close to Stratford Upon Avon to do a clutch?
Si
Si
