coolant leaking!!
Car  2002 clio 172
Drove to Manchester this morning, about 25 miles ish, noticed a bit of smoke coming from front of car, on the passenger side. Pulled over and checked under bonnet, coolant was below minimum. Put water in it from garage and carried on. Pulled up ten/fifteen mins later, coolant had dropped a bit. Drove again for another ten/fifteen mins. Smoke again. Coolant below min again. Car runs fine. Nothin on dash indicating anything wrong. Dipstick and oil filler cap look fine. Am I gonna do damage driving home? What should I do?
Ahh right, more like a split pipe or thermostat housing then mate.
Take the airbox off and have a look, it should be pretty visible with that amount leaking.
Just drove back from Manchester and coolant level hasn't moved at all. No steam or nothing?
Get the coolant changed mate. If you've just put water in after it has lost a lot of coolant, then chances are it could freeze in the cold weather coming up. You don't want that happening.
Didn't even think about doing that! Thanks. Much appreciated.
