New car part 2
  Fiesta ST Stage 3
Going on from this thread http://www.cliosport.net/forum/showthread.php?752174-New-French-Car I picked up my new car on Friday .
Have wanted one for a long time and thought sod it :)
Pic below after a quick wash .
  Fiesta ST Stage 3
I thought you would approve it from the 207 GTI :)
The girlfriend has now got the 207 GTI so it has worked out well .
I still say the 207 GTI is a good car ( if it is working ) and would fit all of my needs but it does not excite me and as much as I tried I could never love / get excited about the car even tho I did like it if that makes sense .
Alan
Well played sir. Infinitely better.
  Fiesta ST Stage 3
Had the first small problem with the Z .
The cooling fans are not kicking in ( common problem ) and the engine will overheat if left at idle .
Nissan want over £ 850 for the fans so have got the below on order with some other bits .
Price
Paid or not
Item dispatched or not
Feedback left or not
Feedback received or not
Actions
Engine Oil & Filter Service Kit: 5L of Fuchs TITAN XTR 5w-30
Engine Oil & Filter Service Kit: 5L of Fuchs TITAN XTR 5w-30 (161174820556)
Member ID opieoils | Feedback score of 16742 | 100.0%
Sale date: 10/09/14
Tracking number: --
£29.09
Free P&P
Paid with PayPal on 2014-09-10.
Not posted
Feedback not left
Positive Feedback received
NISSAN 350 Z 03-09 FUCHS MANUAL GEAR BOX OIL TITAN SINTOFLUID 75W-80
NISSAN 350 Z 03-09 FUCHS MANUAL GEAR BOX OIL TITAN SINTOF... (181494591835)
Member ID ybcarsuk | Feedback score of 15005 | 99.6%
Quantity: 3
Sale date: 10/09/14
Tracking number: --
£32.76
Free P&P
Not posted
Feedback not left
Forte Specialist Petrol Injector Cleaner
Forte Specialist Petrol Injector Cleaner (321451476183)
Member ID sep-direct | Feedback score of 829 | 100.0%
Sale date: 10/09/14
Tracking number: --
£12.95
Free P&P
Not posted
Feedback not left
Feedback not received
NISSAN MICRA ALMERA NAVARA 350Z 200SX SUMP DRAIN PLUG WASHER GENUINE 11026 01M02
NISSAN MICRA ALMERA NAVARA 350Z 200SX SUMP DRAIN PLUG WAS... (111339249524)
Member ID incirclestogo | Feedback score of 9291 | 99.9%
Sale date: 10/09/14
Tracking number: --
£1.75
Free P&P
Not posted
Feedback not left
Z33 350Z 6 x Uprated NGK Iridium Spark Plugs HR5
Z33 350Z 6 x Uprated NGK Iridium Spark Plugs HR5 (131095817530)
Member ID conceptua_performance_tuning | Feedback score of 17108 | 99.9%
Sale date: 10/09/14
Tracking number: --
£49.99
Free P&P
Not posted
Feedback not left
Mishimoto Radiator Fan Shroud Kit - Nissan 350Z VQ35DE - 2003-2006
Mishimoto Radiator Fan Shroud Kit - Nissan 350Z VQ35DE - ... (231308379012)
Member ID mishimoto-trader | Feedback score of 1007 | 100.0%
Sale date: 10/09/14
Tracking number: --
£180.00
Free P&P
Not posted
Feedback not left
Gates OE Alternator Belt & Air Conditioning Belt Nissan 350Z Z33 VQ35DE
Gates OE Alternator Belt & Air Conditioning Belt Nissan 3... (290728783837)
Member ID car_parts_international | Feedback score of 426087 | 99.4%
Sale date: 10/09/14
Tracking number: --
£24.85
Free P&P
Not posted
Feedback not left
Nissan 350Z K&N Typhoon Cold Air induction kit
Nissan 350Z K&N Typhoon Cold Air induction kit (161411638222)
Member ID colquhounmill | Feedback score of 973 | 100.0%
Sale date: 08/09/14
Tracking number: --
£175.00
Free P&P
Paid with PayPal on 2014-09-08.
Not posted
Feedback not left
30mm 3 SAMSUNG SMD LED 269 C5W SV8 CANBUS NO ERROR WHITE NUMBER PLATE LIGHT BULB
30mm 3 SAMSUNG SMD LED 269 C5W SV8 CANBUS NO ERROR WHITE ... (300698507331)
Member ID fizzmocouk | Feedback score of 51386 | 99.7%
Quantity: 2
Sale date: 08/09/14
Tracking number: --
And also H-DEV plenum spacer .
Alan
My 350 looked identical, good choice.
I also had the cooling fan problem, overheated on my twice and chucked coolant everywhere. I ended up paying £800 to get it fixed at Nissan, then sold it a few months later.
Love the noise of these.
  Fiesta ST Stage 3
Been a busy boy this weekend but I have installed all of the below with no major problems ( gear box filler nut and the inlet stud removal ) .
A few pic
First up an engine flush and oil and filter change .
Then was a gearbox oil change
Removed the broken rad fans
Then was the Inlet pendulum spacer
Spark plug change was next
A quick belt change as old one was not in good nick
Then install the new rad fans after some joining of the wires
Then on to the last bit the K & N typhoon
Al done
Next up is a Uprev ( ECU map and de limiter top speed 1 , 2 , 3 gear throttle ) to finish this off .
Alan
  Fiesta ST Stage 3
Did a few other bits at the weekend .
New aerial done
Old one
New one
New wiper blades
Headlight adjust
Fuel sender clean with new O rings
  Fiesta ST Stage 3
At the weekend I did the diff oil change
parts .
The filler plug was a PITA to get off but a bit of heat sorted this .
The plug had some shavings and sludge on it and the oil was a darker honey colour so a change was a good plan .
  Fiesta ST Stage 3
So on Friday I went up to Abbey Motorsport to have some Cobra HFC and a Milltek Y pipe fitted and the Uprev done .
Y pipe
HFC
Uprev with print out
The car started off with low ish numbers but saw some good gains in the end .
+ 19.3 BHP and + 12.9 LB/FT
Converting this in to old money ( on a rolling road and not hub dyno ) this should add 30-40 extra BHP / LB/FT and make the car around 275 BHP an 260 LB/FT
The car Is loosing power and torque with the K & N typhoon fitted as the temp was going up and the std exhaust will not help this as well so if I change this and add a V/S to the air intake we would see around another 7-10 but the extra noise of the K & N is worth the loss so this will be staying .
Alan
Brett
  172 Cup, M2 and MCS
How fast are these? Do they handle nicely?
An old member on here had a 370Z and rated it very highly.
  Fiesta ST Stage 3
Little bit quicker than a MK 6 GOLF GTI I found in my one .
handle nice bit heavy at 1525 KG for the GT pack ones .
I love my one for the looks and noise alone .
Alan
  Fiesta ST Stage 3
Only one point to note is that parts and tuning part are not cheep for this car and you will never gain a lot of BHP on this engine as most make 250 ish not the 275 the book said .
Alan
I end up looking at these once every 6 months as a guy at the top of the hill I live on had an S15 and went to a 350z so always wanted to ask why, But watched a bunch of video's on youtube of these and just the noise alone is a beauty!
  Fiesta ST Stage 3
Another update time .
On Monday went to Abbey Motorsport for some suspension parts and to turn off the engine light that came on after the Uprev .
First was two new banana arms
Then a Whiteline front anti roll bar set to soft with Whiteline drop links .
Then a Whiteline rear anti roll bar set to soft with Whiteline drop links .
And today I set the rear up to medium for the ARB
Car is now much more tight and flat and turn in Is much sharper .
Alan
  Fiesta ST Stage 3
Next small update got round to fitting a few bits .
First up some CREE LED number plate lights
OLD
NEW
Then the bonnet dampers
  Fiesta ST Stage 3
So this weekend was the brake upgrade / change .
Fist up was to remove the front discs and pads .
Front disc not in good shape
Or the pads
Then to fit the new front disc and pads
Then the front S/S brake lines
Then on to the rears with old disc and pads removed
Then to fit the new disc and pads
And the new S/S lines
Then it was a brake fluid flush / bleed to finish off .
And a quick oil and filter change .
  • Alan
  Fiesta ST Stage 3
Ok so after putting a few miles and bedding the brakes in I can report on the set up .
The old brakes were not in the best of shape so any change would be an improvement .
First up is the pedal feel with the new S/S lines the travel so much shorter and the feel so much firmer and all of the dead / squish feel is removed and just a firm reassuring pedal .
Next up is the stopping power from the new discs and the DS2500 pads all round .
Very very strong stopping and no fade even from 70 MPH speeds .
If anyone is thinking about this set up I am very impressed so far .
Alan
  Fiesta ST Stage 3
Not many updates just a quick clean and wax .
Next up will be the exhaust suspension and tyres .
Alan
  Fiesta ST Stage 3
A few more updates over the weekend I got done .
Fist up was to clean then condition the leather seats .
Then was the boot counter weight removal ( boot does not pop up all the time due to this weight )
Then last up was to re adjust the aux and air con belts as there was a little slack and squeaking on start up .
Alan
  Fiesta ST Stage 3
Boot was still a bit sticky so put some plastic washers in the boot spring to fix this and make the boot pop up more .
