my clio 172 cup making a start
What airbox is this its very loud?
[/URL]
Not today but did on Wednesday night taking the misses to tesco
Got a problem just finished work tried to start the car was fine this morning now it's just cranking over but not starting what could be the issue?
tdc sensor or even coolant temp sensor,does your trip computer keep resetting itself
No cud it be the immobiliser on the key?
All fixed pulled out tdc sensor and just gave the points a clean and hay presto started first time
Think I've just seen this mate did you drive past camberley kwik fit on the a30?!
You local then mate
Arctic blue 182 :)
Haven't seen many others round here though haha just us 2 by the look of it!
Arctic blue 182 :smile:
yes bud hopefully see you around the manor
When does the vvt kick in a does it do it all the time?
Mines around 5200rpm I can feel a slight kick and Indiction kit gets a fair bit louder (Ktr Induction)
That's quite early mate mines about 6000 don't have a induction kit yet have the clio v6 box
Just before that actually more like 5600 getting fatty induction kit hopefully for Xmas will have to see what santa brings me lol
What people's options on that induction kit got the v6 at the moment
if u want more noise get the fatty one, u wont notice any differnce in performance though, but they do sound good.
No worries. I had the ktec induction kit on my ph1 172 and loved the noise it made.
My oil display has just come on checked the dip stick where should it read on the dip stick
Am freaking out its got no oil in it?
Pulled it out and it's on the first indicator
So when it's under the first one it means it's empty?
Anyone?
Had a bit of white paper under the car all day and had two tiny spots on it should I be worried?
Do clios leak much oil?
Hard to tell with leaking On the clios because of the padded undertray but I'd definatly say it shouldn't be leaking at all mate get it in the air and have a look! :)
Took it to halfords on Saturday they cleaned it up and said keep a eye on it
Where do they usually leak from?
You'll need to get under there and take the tray off to see if you can trace it, it could be as simple as someone not using a new crush washer on the sump plug!
Yes will have a look cheers bud
Hard to tell with leaking On the clios because of the padded undertray but I'd definatly say it shouldn't be leaking at all mate get it in the air and have a look! :smile:
May have to pop it in your place mate get you to shed some light on it bud lol
Since I have had the car I have been sticking v power in it and I am really notice the difference in power not to sure what the previous owner put in it
@andy1982 hello mate, I've just been through the thread and merged a load of your consecutive posts. If you want to add information to your last post then please use the edit tool rather than posting 2 or 3 messages one after the other!
