LED conversion, complete list of LED bulbs please
GrahamS
  335d, GT4
I've been looking around the site for ages this evening and there isn't a complete list of the bulbs needed for the dash conversion. I'll put down what I know but if someone could help me fill in the blanks that would be brilliant. @McGherkin @MWright maybe you guys can help
Clocks (needle type)
10 plcc-2 (4 for display, 6 for needles)
Digital
4 plcc-2 for needles
4 plcc-4 for display
Update list display
4 plcc-4
Tuner list display
Climate control
28 LEDs but which types?
Manual heater control panel
Radio
Window switches
ESP/Cruise switch
Central locking button/rear window heater
GrahamS
  335d, GT4
@msremmert I'm going to get them individually as it's a huge amount cheaper and I'm a cheapskate. No no! Red display! Like an Audi. I love my clocks :)
I'll try and take apart some components later to get the exact sizes of a few more bits
GrahamS
  335d, GT4
okay so this is what I've been able to establish
Digital
Update list display
4 plcc-4
Tuner list display
Climate control
28 LEDs all plcc-2
Radio
Window switches
3mm dome topped led although flat top is fine
ESP/Cruise switch
3mm dome topped with inline 420ohm resistor to allow 12v
3mm led dome topped, again flat is fine
this is a quick few pics on how the rear window demist comes apart. All these kind of switches are the same. Be careful you don't unsolder the whole piece of copper as it's rather easy to do. Being careful it takes about 10 minutes per LED replacement.
The circuit board then comes off the pins if you prise is very carefully.
Note which way round the LED is, cathode and anode. Compare it to your new ones as it's fairly obvious. If you mount it the wrong way it won't work. On the below pic you can see the resistor in the board which allows the LED to work with 12v. Only the cruise control (maybe esp too) doesn't have this so you have to add the resistor in (very bottom pic)
Ol’ Tarby
  Clio 220 Trophy
Do you have any links for each blub mate?
Going to be changing mine to blue I think, to match my alpine head unit
McGherkin
McPension
The manual heater control panel is T5 capless wedge IIRC, but the contacts are f**king awful so it's easier to use strips soldered directly onto the pins on the circuit board that the main electrical connector uses.
(Cheers @Chris_Beer )
@james24785 don't go blue. You'll regret it.
  Clio 182 - RB
Does anybody do this in the North West? Ideally local to the SK10 (Macclesfield, Cheshire) area [emoji4]
GrahamS
  335d, GT4
to finalise. Hope this if of someuse to people.
It can easily take half a day to do this.
My tips would be to use a flat blade soldering iron and cut off tiny piece of solder. Hold the SMD in place, put the tiny piece solder next to the joint and then use the iron, otherwise it just gets a bit messy and you end up melting SMDs or having huge chunks of solder. If some of the radio ones don't work it's because they are in grouped circuits e.g. if the smd under "1" isn't attached properly then "2" won't work either even if correctly attached.
Digital
Update list display
4 plcc-4
Tuner list display
Climate control
28 LEDs all plcc-2 careful as two of the vent directional LEDs have the opposite polarity to the other 26.
Radio
11 plcc-2 with contacts bent out as they solder on the other way
Window switches
ESP/Cruise switch
