Camber wanted
Hi guys had my b14 fitted yesterday and they said they could only get 1.1degree Camber on the front and I have eibach Camber bolts already he was saying I would need rose jointed wishbones or somthin how are you guys getting 2+ degrees
Nope this is the sheet.
Just so I can go back to them with some info what should I be able to get on b14s camber bolts and pms top mounts
charltjr
Can't help with the B14's specifically but these are my settings on cooksports, standard cup shocks, PMS solid top mounts and eibach camber bolts. I can't see why the B14's would be so much less adjustable.
imprezaworks
  Mk5 Golf GTI :)
I have b14's with camber bolts. My settings are around -1.5 on the front. The 'recommended' garage said to add more camber I need bolts. See above :(. I will be at some point run -2.5 ish. The rear is -2 but I have shims. Thinking outloud are the bolts in correctly, the tab iirc should be near the shock end if that makes sense mate
Thanks for everyones help Taking it back there tomorrow will get it on the ramp see if we can see anything amiss take some pics etc just a thought what size (mm) are the eibach bolts are the pms ones longer meaning maybe more camber available
imprezaworks
  Mk5 Golf GTI :)
Different bolts wont affect the amount of camber afaik. Hence why people including me buy the eibach ones as they are the cheapest.
green
  Hi comp phase 1
As cub says.... Don't go back to those muppets! Go to someone who knows about changing geo settings.
Don't want to name the company as could just be human error different set of eyes different day could be all that's needed but they do have clio customers racing in the cup series etc and are only a motorsport garage not the likes of kwik fit so will give them a chance but they will only get one then I'll go else where
I'm not in Northants, I'm not a motorsport garage, but I do know how to set up camber and toe if your interested. Based in Lichfield.
May end up taking you up on that will give them a chance if they don't sort it then will go from there. thanks for the offer appreciate it
Does anyone have any pictures of how the camber bolts are ment to be fitted top or bottom inside outside etc cars going up on the ramp tomorrow so want to be able to spot anything out of place and tell them fit them like this etc. Also I replaced the rear rubber top mounts at the time of fitting coilovers as the ones that where on there didn't match so I now have powerflex purple (fast road) but getting some knocking is this due to the rubbers not being OEM or the fitting
Thanks everyone for your help went back went back and got a couple of gremlins sorted now feels much better a lot more eager to scramble to the apex
