The Contrôle Technique (french MOT) was due this month but I had some issues :
- one of the indicator (the one in the headlight) wasn't working and this wasn't a fuse/bulb issue
- one of the new headlights was higher than the other one
- the A/C wouldn't blow any cold air even after a refill
- needed to mount back the rear seats (they have to test the seatbelts)
Then I also bought :
- front and rear wiper blades
- Speedline center wheel caps
- cabin filter
So changed the wiper blades (easy), the cabin filter (where the heck it is located again, ah ok found it) which miraculously solved the A/C problem. Then I put back the rear seats and decided it was nicer (less noise) so I sold the K-tec mat (it went in less than 10 minutes !). Had to put down the whole front bumper to check the indicator issue and it was just a bad connection (1 hour alone for this).
Next day I received the wheel center caps and they wouldn't fit at all. was pretty pissed at the time so had to take the wheels off and file the plastic. Then alas the nice sound of the thing getting into the wheel... I also checked the brake pads and they were all ok, so gave the wheels a clean.  Car looks pretty good now imho :
And on the next morning I went for the CT and was pleased to hear that they were no default at all.
Still, have to fix an air leaking near the rear exhaust and a noisy front shock on speed bumps...
