My 182 for daily use
Car  Clio Sport 182
Hello again
My name is Paris and this is my new daily toy. Sorry for my English. Is not my native language.
So my car is a 182 with trophy wheels. No other mods. For now!!!
I picked this up on Saturday and the first clean took place Tuesday using claybar.
The car over all is in really good condition with only 61k on the clock and is coming with full Renault history. All the usual staff like cambelt, pulley, brake fluid, coolant have been done 2K ago.
So my plan for now is to improve the areas that can make the car look better as my budget is limited after buying the car:
So:
1) Refurb headlights
2) Do something with the steering wheel because its looks really bad and destroys the overall condition of the interior.
3) Replace the jet washers
4) Try to repair or at list to reduce a scratch that i have in the passenger’s side
5) My exhaust leaks from somewhere. Is couple of months old so I hope that is not require changing and with a small repair will be fine.
I think this is it for now. Later on I will upload some pictures from the areas that they need improvement
Regards
Paris
A small update. i have done my head lights and i'm really pleased.
And few pictures with the car washed and polished @GoodWood
Today i had the time to spent on the car so i dissed to clean my dirty seat-belts.
Some pictures before:
during washing with turtle wax
Half way
Final result. So happy.!!!!!!!
Hi Paris182. Seen you at Micks a couple of times. I'm just doing my headlights. How did you do yours?
You will need a 1200 & 2000 wet & dry paper and a rotary polisher. Go with the 1200 paper first then with the 2000. Make sure that is wet and you keep the headlights wet when you rubbing them. Then using the rotary polisher you polishing the lense. Unfortunately on this stage I had to go to my mates place as I do not have a polisher
Had a delivery today.....
172 Cup Front shocks and 182 Cup rear shock to go on my non cup 182 with Eibach Pro springs.
I think is the best solution for an daily use car.
Fully fitted and really pleased. a bit firmer on straight line and really good in corners. Worth the every penny.
I will upload few pictures later on
Happy new year
Few pictures lowered and with front spoiler and with my mates M3 (last picture)
@Archtronics can i ask you a silly question as you have the same setup?
Do you have a lot pedal travel now? i need to press the pedal almost to the floor for the car to start braking.
Thanks
Thanks
No, they are more progressive than standard but same pedal travel as before.
Did you bleed the system with fresh fluid after fitting them?
