brake advice
Car  182
You see the little mini pistons on either side of the caliper (not sure of their name) should there by any resistance at all in them?? I'm able to move the carrier etc very freely
Is it a case of cutting the pads to the shape of the pads and use the grease to apply the them to the back of the pads
Exactly that. Just make sure the pad is covering the part of the brake pad the piston presses against.
Have you not used these before then? Well according to your post you have. What have you done in the past just left them on?
I use them for 4 pot brembos which dont have that metal shim bit.
