Love this mate!
Whats the spec?
Sent from my HTC 10 using Tapatalk
Copy and pasted.
ENGINE  AND  TRANSMISSION
Citroen C2 VTS engine (covered 3k)  Year 2007 Engine Code TU5JP4S
C2 inlet modified to fit saxo throttle body and fuel rail
Wossner low compression pistons
Wossner forged conrods
ARP Conrod Bolts
Ported head with 3 way valve seats
Piper Turbo Cams
Modified crank with longer woodruff key
Standard head gasket
Peugeot sport baffled sump kit
Pico 500cc 12 hole injectors
13 row oil cooler (engine oil)
13 row oil cooler (supercharger oil)
GMC single pass ally intercooler
GMC ally radiator
GMC header tank
GMC supercharger bracket
GMC 4 – 1 manifold heat wrapped/painted
BTB exhaust
Rotrex supercharger C30/84
6 rib belt set up
DTA S40 PRO engine management
Innovate LC-1 wideband lambda with display
3 bar map sensor
Peugeot sport group A engine mounts
K n N airfilter
Custom made stainless catch tank
Custom made boost and intake stainless pipes
Custom made ally swirl pot
Bosch 044 Fuel pump
Bosch idle control valve
MA citroen saxo vts gearbox
Quaife lsd
Helix 4 paddle clutch
Standard citroen saxo vts drive shafts
SUSPENSION
Billstein group n front/ rear dampers
GMC 40mm springs
Polyrace front arm bushes
Ally wishbone bushes
Pug sport group n top mounts
Rear beam refurbed and set to match front
Rear 24mm anti roll bar
Pug sport group n rear axle mounts
STEERING MECHANISM
Citroen non power steering rack fitted
OMP flocked steering wheel fitted
BRAKES
406 coupe non abs master cylinder
Equip braided lines through out
Willwood rear brake bias valve
Front callipers -Willwood midilite 4 pots
Rear callipers - Standard
Front pads – Carbo-tech medium compound
Rear pads – Carbo-tech medium compound
Front discs – Willwood solid 285mm
Rear discs - standard
RBS 600 brake fluid
BODY AND CHASSIS
New non sunroof roof skin fitted
OMP 10 point roll cage
WHEELS/TYRES
Speedline comp 2’s  15inch x 6.5 wheels
Yoko 195/45/15 tyres
ACCESSORIES AND ADDITIONAL MODIFICATIONS
Aero catch lockable bonnet pins
Morrete grill and head lights
Smoked front indicators
Front bumper mouth cut out and meshed
Fog lights removed and meshed
Smoked rear lights
OMP WRC bucket seats
OMP side mounts
OMP racing 4M harnesses
Flocked saxo vtr dash board modified to accommodate cage
Middle air vent removed to fit twin gauge pod
SPA twin digital gauge boost/inlet temp
SPA twin digital gauge supercharger oil temp/fuel pressure
Innovate wide band lambda display
Carbon front/rear door cards
Ally quick shift
SDash logging and gauge display
