Engine rebuild or new engine??
  Clio 182
Hi all my 182 has started to to knock, not much just small amount. I'm trying to think what to do next rebuild it or new engine I've not got much money so cheapest best option??
  renault clio 1.4 16v
can always re-build it mate, new bottom end bearings, line bore, check the rings and stuff...
  Clio 182
I was hoping just bottom end bearings and crank regrind but that's past my knowledge. How would I know if I need oversized bearings etc..
GrahamS
Until you get the sump off you really can't tell. If you take the crank off you're looking at needing a new cambelt which straight away makes it more efficient to get a different engine with the belts already done.
You'd have the machine shop measure the crank journals to see if they're in spec.
  Clio 182
thats ace thank you very much. so i need a new motor, i guessing the 172 motor is basicl the same as a 182 just different brackets etc..
