Obviously give the window a good clean in the normal way before application [emoji1303]Try applying a few coats of rainex to the window, it's should change how the water sits/behaves on the glass
Being a 5dr makes no difference? Visibility is seriously hindered, it's right in my line of sight and I can't see out of the mirrors. I'll try rain-x but to be honest i'll be getting rid of this car soon anyway.I know what you mean by it swirling in the corner near the plastic trim, but the mirrors are stuck out a few inches past that so i'm a bit confused.
what it does... View attachment 169599
Got some hekos on my 182, so looking forward to trying these out. Good shout though, but as I said not looking to spend more and more on this car. Just want the little kinks fixing. Didn't know if i'd experience similar on my 182 or if there was a simple fix.^^^love that :up:
On a serious note, I've just bought some G3 wind deflectors, £22 and they are really good quality, fit well, look good, better than the Heko ones imo. They would stop that and reduce wind noise in the car when on motorways etc with the windows down a couple of inches. Just a thought
Puddle maybe wasnt the best explanation, ahaha, it's more just building up in that corner, then travelling down the rest of the window.Drill a hole under said puddle and filter into an empty can?
Can't see any other way tbh
Ps hope you sort it :smile:
I believe so, ill give them a smack tonight to make sure they're clipped in. This is the appropriate way to deal with all plastic clips on the clio, right?Are the seals sat properly. Can't say ever come across this on here before
Think you need a few points for that trick. [emoji6]Because you asked so nicely.
http://bit.do/Facebook145039209
Points mean prizesThink you need a few points for that trick. [emoji6]
Im the prize king!Points mean prizes
That was a low blowThis problem on a 1.2 you say? It's probably just not fast enough to blow the water off the windows. [emoji23]
