Jazzing up the Combo van.
Car  A special one.
So after 7 years of owning my Combo 1.7 dti (with a whopping 75hp, it has an intercooler don't you know) i thought give it a bit of loving...😂
Id like a newer van, a VW Caddy maxi would be nice but i just don't have the funds or can i really justify it. I use the van as my daily and if it wasn't for the fact that ive been using it to go to customers houses to valet there cars then i would have sold it and bought a old Volvo estate the same as @leeds_182 has, tbh its Jim's fault that ive started messing with the Combo.
As i said i don't have alot of funds so i wanted to do bits that didn't cost alot of money, one of the first things was a good machine polish as the old paint was proper flat. Ive made a start by polishing the rear doors and the drivers side 1/4 panel.
I removed the rear badges as well to try and give it a cleaner look (if that's possible with a stupid looking box van)
The old bus.
20160926_173219 by Scott Raven, on Flickr
Rear door's polished.
20160922_173204 by Scott Raven, on Flickr
Still loads more polishing to do and ill just do it a panel at a time. I did a silly thing and started looking at lowered vans on Google and came across this. :hearteyes:😂
After seeing that picture i was now on the hut for a set of wheels, my van is running a 175/70/14 so i wanted to go to a 15" steel.
I found the Corsa SXI used a 185/55/15 and i started finding the odd new steel wheel on Ebay with new Pirelli P6000 tyre, maybe not the best tyres but its only for my van and they are new.
I have 4 now + a spare wheel.
20160930_165735 by Scott Raven, on Flickr
20160930_165724 by Scott Raven, on Flickr
The van is up for a big service, service parts + ball joints + front brakes so i thought i would buy a pair of bigger calipers as i need to replace the discs and pads. The calipers came from a Meriva which ive cleaned up ready for a coat of paint. Im going from a 260mm disc to a 280mm disc, didnt need to as i only do 65mph in the thing, but in my mind i didnt want smaller brakes behind a larger wheel...😂
I sent the pad carriers to the powder coaters along with the spare wheel (i just can't help myself) :fearscream:
20161008_110514 by Scott Raven, on Flickr
20161008_110845 by Scott Raven, on Flickr
20161008_110910 by Scott Raven, on Flickr
Before i had the carriers powder coated i trial fitted them to the van, quite a bit of difference tbh.
Standard
20161001_143357 by Scott Raven, on Flickr
Meriva
20161001_144352 by Scott Raven, on Flickr
260 mm disc with the 280mm pads. :tonguewink:
20161001_144804 by Scott Raven, on Flickr
Bought all of the service parts from ECP along with the brakes, only the best for my van. :laughing:
20161003_132619 by Scott Raven, on Flickr
Back to the suspension, i know that the front of the van is the same as the Corsa C so sorting out the lowering of that wasn't a problem but i didn't know what the rear set up was. After a bit of research i found out that it was the same as a MK4 Astra, now this became a problem as no one would do a lowering kit for Corsa C front and MK4 Astra rear. 😞
Im lucky enough to have Gaz about 20 minutes away from my house so after a call to them i had the van booked in for them to have a look at it on there ramp.
20161003_095005 by Scott Raven, on Flickr
After a quick look they said they could do my a full kit but it was more than i wanted to spend so i left it at that.
A bit more googling and i found that standard MK4 Astra springs can be used so i bought a pair for the grand sum of £20 delivered, yes they are alot shorter but they are also made of thinner wire (14mm vs 11mm) as it was such a small cost it was worth chucking them in.
20161029_142239 by Scott Raven, on Flickr
I was thinking they would be fine as i dont carry anything in the van, this is the height with the standard springs.
20161029_103708 by Scott Raven, on Flickr
With me being such a big kid i fitted the Astra springs and the 15" wheels and this is how it looked. :cool:
20161029_154139 by Scott Raven, on Flickr
20161029_154301 by Scott Raven, on Flickr
Ill up date some more tomo. :up:
Get it mapped ! Only something like 100hp but makes them hell of allot more nippy.
Love these, altho I have a soft spot for Astra mk4 gsi rep vans
Not a bad drop for how cheap them springs were.
Glad to see the wheel got there in one piece, cling film FTW!
Springs will be fine as you don't carry lots of weight .
At least steels probably don't need insurance change either.
Cheers mate, oh and hello stranger. [emoji106]
I would love to get it mapped but I'm not willing to spend £300 doing it!
Do you know of anyone mate? (My van has the Isuzu 1.7 dti engine)
Needs spacers! ;)
It looks much better on those wheels etc bud :up:
Haha, it does mate.
I have looked into getting the wheel's banded the same as Jim's Volvo but it worked out at over £200 plus I'm sure I'd need wider tyre's.
It I'll do for now, I've just protected the wheel's for now so it maybe something I do next year, we shall see. [emoji4]
Looks very clean and pretty.
Still not seen a nicer van than the mk3 Astra though. Was my 90's wet dream with some neons.
You're such a p1ss taker Pete...[emoji23]
Nope being serious, ever since I was a young one I wanted a bodykitted mk3 Astra van lowered in purple with neons. I used to walk past one all the time on the way to school.
I'm not sure what the bloke did for a living but the van was on the drive all day and only disappeared during the evening. I'm pretty sure he got the bus to work as well.
Like this it would look
Thanks again mate for all your help, it was wrapped up errrr, rather well....😂
I dont but when i put some of my valeting stuff in the back the van did sit quite low at the rear and when i went over speed humps it hit the bump stops. Its not the end of the world as ill go back to GAZ in the new year and get them to make me some lover but thicker springs up.
With those springs on it, I'm guessing you're not expecting any heavy loads again :smile:
At the moment i drive it about empty mate, ill be looking into stiffer springs in the new year bud.
Before i fitted the springs i wanted to clean out the rear wheel arches, G101 a soft brush and the hose sorted this out.
20161029_114816 by Scott Raven, on Flickr
20161029_122750 by Scott Raven, on Flickr
20161029_133003 by Scott Raven, on Flickr
Always get carried away when cleaning so i ended up cleaning the underside, i wanted to treat the rusty areas anyway and give it a good coat of wax oil.
20161029_140258 by Scott Raven, on Flickr
20161029_140349 by Scott Raven, on Flickr
Im going to give my local pipe craft a call to see if they can remove the rear box and make me up a stright through pipe, im sure it won't make it loud.
Once all of the cleaning was done i fitted the springs to see how compressed they where, not to bad but being thin they compress to much and hit the bump stop.
20161029_152620 by Scott Raven, on Flickr
For now ive kept the van on its standard 14" wheels, yesterday i gave GAZ a call and have placed an order for a pair of front coilovers. :fearscream:
Looking forward to getting them now so the van wont look like a speed boat...😂
20161030_152617 by Scott Raven, on Flickr
One day yours will look like that red one....
The red one is only slammed on coilovers mate with a FMIC, i think its only about 100bhp. I cant be sure if its running standard steel wheels or they have been banded.
In a few weeks when i get my GAZ front coilovers my van will be low, ill go back to GAZ in the new year and get them to sort the rear springs/shocks out.
Hello! Hope your keeping well dude !
Yeah mapping is expensive , don't really know allot of remap people.
Only dervtech, cdti surgery ( big Vauxhall diesel tuning company)
And narco tuning up here near me.
After placing the order for the GAZ i was told id have to wait 3 - 4 weeks as they are made to order. On Monday i had a call to say that they where ready for collection.
My wife went over to GAZ this afternoon and collected these. :cool:
20161123_175443 by Scott Raven, on Flickr
20161123_192815 by Scott Raven, on Flickr
20161123_192547 by Scott Raven, on Flickr
If im honest then im very happy, the quality is great and i was even happier when i saw that they where top damping adjustable (i wasn't told this when i ordered them)
SO now all i need is a couple of nice days to fit the front shocks and give the van a big service, once that's all done ill head over to GAZ and get them to make a new thicker and lower pair of rear springs with shocks to match.
I had the same van for a couple of years - I thought it was great compared to the tranny connect I had.
It's not a bad old bus mate, it just gets me to work and back and a bit of mobile valeting at the weekends.
ph2 front end next!
Haha, I wasn't meant to be spending any money on the van just wanted to clean it up after 7 years of neglect.
Thank God GAZ didn't give my wife the invoice for the shocks...[emoji23]
"Can't justify a couple hundred for a remap"
*Buys GAZ coilies*
Please let me have some of your train of thought Scott! 😂
You don't need gaz coilovers for the daily commute either :tongueout:
Seriously though good work!
I know mate and I knew you was going to say that!
The old 14" wheels are rusty and bleed rust over the tyre's when it rains.
So I bought 15" wheels with a lower profile tyre, this wouldn't look right on the van so it needed to be lowered...
Knock on affect, made perfect sense in my mind anyway. [emoji23]
*Buys GAZ coilies*
Bit mental aren't i?
I don't drive the van fast mate, it's a van.
All I am trying to do is make it look a bit better, plus I've said to tania I won't spend anything on the impreza.
I get bored very easy so this takes up a bit of my time. [emoji4]
