Squeaking/creak sound (video)
No still does it if brake pedal is on
I assume it does not do it driven in a straight line.?
Sounds as if the disc is rubbing on the caliper,so check the wheel bearing,the hub centre nut & wheel nuts.Also that the disc positioning grub screws do not sit proud of the disc.
Failing that,outer CV joint or both?
Yes only when turning hard, I'll have to have a look into this then, hopefully we get a dry weekend sometime soon..
I'm running spacers, could this be a factor?
