Did you use a screwdriver on the connector at the back? Otherwise it just doesnt like you
did you manage to get the fuse out on your own by the way or did you have to get a grown up to help:tongueclosed::tongueclosed::tongueclosed::tongueclosed:
Haha shh, i used the snazzy orange thing!
Carl is that you in the picture?did you manage to get the fuse out on your own by the way or did you have to get a grown up to help:tongueclosed::tongueclosed::tongueclosed:
On the third brake light. Going off all the electrical tape I wasn't sure if it was dodgy@bloke seriously though, did I somehow make the fuse blow, or does it just happen?
Give him £2k and save the poor thing. [emoji23] [emoji23] [emoji23]Was going to offer 500 for the car damn that fuse
it's davvy :wink:
ignition on or switched to accessories when you unplugged it? what's the score with tape? pic? could be a short.
You've been mega unlucky lately mate.
There's never such thing as a daft question. Just ask @dann2707 how many stupid questions I've asked him.
I once had the engine running when I was filling my washer fluid up and thought to myself, God that's windy in my engine bay. Stuck my hand down and nearly took my finger ends off with the fan. Turns out I had my AC on, which resulted in the fan being on which meant it was quite breezy under the bonnet![]()
That's brilliant, hahaha. Could've ended badly!You've been mega unlucky lately mate.
Keys were out of ignition iirc. Tape looked to just be holding the wires together, around the connectors.
That connector under the tape just doesn't look standard though, I'm probably wrong but looks different to mine but it's hard to tell.
Not standard i dont think, can't remember what mine was now, but im sure it was both wires going into a single connector rather than individual ones. Wonder if someones had a butcher. Think the wirings often different from cup spoilers to normal spoilers so they may have had to cut and solder to get it fitted. I'd remove all the tape and get a better look mate.It was just like a ball and socket connector for each wire.. dont know the technical term.
Yeah, not standard. Are the other two ends that are connected to the cars loom protected with heatshrink or just the bare metal 'prong'?
Tried disconnecting the battery?
