SQ5
The problem you have is the RJ45 ports on your NVR for the cameras isn't anything to do with the RJ45 port for your Ethernet.
They don't connect in anyway.
All your cameras need to be the same as the internal IP4 address, for some reason it looks like IP4 is turned off on your DVR. I would turn IPV6 off on your router and make the IPV4 Address the same as your router which I'm guessing is 192.168.1.***
If you've got a BT home hub you want that address to be .10 or anything below .64 ideally.
