HDMI 4K cables?
Is there anything to look out for? Prices vary so much!
Looked on Amazon and these seem to be the highest reviewed!
Cheapest (and best seller) at like £6:
https://www.amazon.co.uk/gp/product/B01ESLIPVM/?tag=cliospnet01-21
And another at £7
Most expensive at £15:
What are you using it for?
If its just to connect something like a computer to a 4k TV, an Amazon basics cable will do the job...
https://www.amazon.co.uk/dp/B014I8SIJY/?tag=cliospnet01-21
Or even a v1.4 cable from wilko will work (£2 for 1m)
And another at £7
Just get the Amazon basics one then.
https://www.amazon.co.uk/gp/product/B014I8SIJY/?tag=cliospnet01-21
There will be no perceivable quality difference by spending any more.
For some uneducated reason I thought I would need something better for 4K, but probably been taken in by the marketing blurb!
buy the cheapest one you can find, being digital an HDMI cable will either work or not work, not like a scart cable for example where different cables gave different quality picture.
I had an Amazon Basics cable that I purchased a couple of months back and despite supposedly being fully up to standard, the PS4 Pro didn't like it and wouldn't give me the full 4K with HDR etc.
In my experience it isn't as simple as just buying any cable that meets the High Speed HDMI standard. I've had too many that the PS4 Pro didn't like although the Xbox One is far less fussy.
That Amazon cable that didn't fully support 4K was only 1.8m or something. The longer you go, the greater the risk of it not working too.
The PS4 Pro is such a whiny sensitive little b**ch when it comes to cables that as soon as I see it being mentioned I feel I have to warn you....
Doesn't the PS4 Pro come with a HDMI cable?
That would seem the sensible thing for Sony to do if the console is funny about the cables it takes.
Does anyone know if the Xbox one s HDMI cable is 4k compatible? (The one s is 4k so I would assume they would give you a cable that could then use said 4k?)
I've got the amazon basic HDMI cable the supports upto 8k or something daft. It was around £8/9 delivered and works very well. I'd recommend
