Cleaning an induction kit filter?
The_Pirate
Car  Golf R
Its actually for the Civic but hey, the place is a treasure trove of info!
I'm potentially buying a k&n induction kit (2nd hand) this week. The thing is in good condition however the filter is a touch dirty, are these easily cleaned? Specific method?
Cheers!
Danké for your help lads! Hopefully get it picked up on Friday for aw the bwwwwwaahhh patter.
I bought 2 k&n cleaning kits from Eurocar parts for 18 quid,just make sure you get plenty of cleaning fluid as the oil lasts for ages.
Use Autoglym engine and machine cleaner . Squirt it liberally all over the filter then wash it under the tap from the inside out pushing the dirt out , then recoat with oil .
I have one on my driveway, I'll check*
*in two weeks when I'm back off holiday... x
Ive always washed mine with soapy water until clean, rinsed thoroughly and then stood on the garden wall to air dry.
I would never oil them, it just causes problems.
That's fine as long as you have a filter that doesn't require oil.
Running a K&N without oil for example, you may as well not bother with a filter at all. It's the oil that catches the dirt and stops it from entering the engine.
Same here. But then I use the oil spray on it afterwards. Rather than get your hands coated in the stuff as well, I normally chuck the freshly cleaned filter into a carrier bag and spray into the bag. Then just keep squeezing and kneading it until it's properly covered.
EP3 Type R doesn't run a MAF so it's not so bad using an oil type filter, might still be worth checking the MAP sensor and IAT sensor to ensure they're clean.
K&N is a cotton filter element, cleaning with petrol can damage the filter element.
Warm water or the K&N filter recharger kits are the best bet.
The filter needs re-oiling after, the oil does all the actual filtering of the crap out of the air.
