Clio 182 Cup Heaters and UCH
So, I am after some advice now. I have been driving my cup for nearly 2 months now and i have noticed two problems.
1. The wipers, indicators and windows are intermittent and work when you first start the car but then they all stop working at together, random times for random amounts of time then all start working again at the same time, if you restart the car then they all work fine again, I have a suspicion that it is the UCH, would i be correct in thinking this and has anyone had this replaced? if so what was the cost?
2. My heaters worked perfectly fine when i first bought the car, but after a few weeks they started being intermittent, and now they vary rarely come on and if they do it's when ever they want to and not for very long at all, I have a 182 cup, does the cup still have the heater resister and could this be the culprit?
Cheers in advance Dave
what do you mean with work, produce heat or the fan?
do a search for heater risitor or something, I think there is something in the guides
The blowers don't work at all buddy on any setting, panel lights up, but they don't blow at all.
I bought a new resistor but stupid me forgot to check my car before i bought one, apparently the clio 182 cup doesn't have a resistor, or if it does its been hidden really well.
Have you checked behind the panel to see if it's plugged in securely? Failing that I'd be inclined to think the fan is dead.
I took it apart but only had a spare 10 mins to have a look.
Does anyone know why the cup doesnt have the resistor?
looks like im going to have to check all connections and hope the fan isnt dead like you say :(
there will be a resistor somewhere but just in a different place I would of thought, the resistor is what gives the varying fan speeds
Is it attached to the fan speed nob on the back?
182 cups use a manual panel don't they to control speed?
