Been a while since I updated this thread because nothing much has happened. Car went for MOT today - here's what it failed on (it is a Turd after all)
Shithouse anyways, asking for £275 to sort it all - too much if you ask me. Main things are the ball joints - other bits I can (probably) sort myself.
- Headlights too cloudy to produce a clear beam (not sure if he's having me on here or not).
- It's a real thing, and such an easy job to rectify. Buy some wet and dry, 1500-2000, then get some cutting compound on them.
- Washers for windscreen are blocked (probs just need a clean haven't used in ages - don't even know if theres washer fluid in there :laughing
- Why wouldn't you check for fluid before taking it for test? I tend to check over everything simple beforehand, it saves so much time.
- Windscreen wipers not clearing windscreen well enough.
- Did he specify how he was checking this? Were they squeaking on the glass or something?
- Rear seat belt won't go into buckle (I suspect some glass has got in from when someone broke in)
- Vacuum on the buckle if you think it's glass, but c'mon now, so easy to check prior to MOT!
- One of the seat belts (cant remember which) doesn't come in and out properly.
- Might need replacing? Hard to really know without being there. Could be it's loose causing it to lock off as at the wrong angle.
- Ball joints are worn (something like that) - not sure if he's on about lower ball joint or whole thing that connects to the hub.
- Very simple job that you can do yourself and cost you very little. If it's a shitbox you might not even want to use genuine parts, it's upto you.
- Airbag light is on - it comes on and off at different points when driving so i reckon its dodgey wiring (it is French after all) - he said he's gonna look into it for me.
- Wiring under the seats most likely.
