CCTV what have you got? Advice needed
  Civic Type R FN2
Sorry to hijack this thread, but I've just found these in the house.
If I bought a DVR (eg this one with a wireless adaptor http://www.ebay.co.uk/itm/252714040...49&var=551908838387&ssPageName=STRK:MEBIDX:IT) would it work alright?
Mr R.
  A special one.
Guys I'm after a CCTV set up but I only need 1 good camera to watch the cars on the drive.
I had a look in Maplin and after speaking to a sales guy he recommended this.
Now as you can probably tell I know fcuk all so any help will be great.
  Golf Gti edition 30
Picture quality on this combination is about as good as you can get without going crazy money with ip cams and even still its hard to tell the difference its that good.Really easy to use and setting up viewing on your mob is simple.
GiT
  Shit little Yaris...
I use HikVision cameras (POE) using a mini PC as a server (recorder).
Gaz_
  Extreme mode
Now as you can probably tell I know fcuk all so any help will be great. View attachment 1343948
Just don't
I do this for a living
HIKvision or Dahua
Id be looking at little NVR, with at least 3/4MP cameras at a minimum these days. Longs you can make an Rj45 plug get an nvr with built in POE and it's plug & play really, no need for servers etc
Swann are w**k, more obvious at night, poor infrared, rubbish chipsets...... just poor DIY quality
Just ask yourself what's the point in buying a cheap camera system? Yes you might see something happening, but if you can't identify, it's worthless?
Some info here
https://www.cctv-information.co.uk/i/Home_Office_Recommendations_for_Facial_Recognition_-_Simple
JohnnyE
  ITB'd Clio
People see cheap stuff on the net, not worth buying just spend a bit extra and get decent stuff as Gaz says. Hik or Dahua.....
Mr R.
  A special one.
Just don't
HIKvision or Dahua
Some info here
Thank you mate, I appreciate that. In the shop that set up looked fine but I'm glad I asked before buying.
I'll look into the stuff you've recommend.
Can I buy the stuff from anyone on the net or is there any links to the stuff I need?
R3k1355
Absolute wetter.
You can see why people go for stuff like the Swann kit, Hikvision have a huge array of cameras.
Its real easy to get confused with all the stuff they offer.
GiT
https://www.amazon.co.uk/dp/B017C4CCI4/?tag=cliospnet01-21
These + a decent 4 port POE hub is what I have.
Andy_con
  clio 182
I have a hikvision NVR and a few Chinese cameras, they work a treat. my dome camera is really good quality, ill post up the make later. but I have just moved house a need two more domes
I have recently bought the below items from the website USE-IP, the camera with a 4mm lens. Very impressed, easy to use, reliable, impressive image quality. A few friends have bought the same setup from the same shop (as said you can get lost in the large range of products). Just add a HDD.
Hikvision DS-7604NI-K1-4P
and
Hikvision DS-2CD2355FWD-I
Mr R.
  A special one.
Yes mate, I need links of every bit that I need. That way I can just add it to the basket and pay.
Simple.
Andy_con
  clio 182
the dome I currently have is Anran on ebay, its a cracking camera.
but just had a look on ebay and they don't seem to sell similar these days
Herr Flick
aka Herman Ze German
I know this probably sounds daft and obvious but my cameras are 1080p and I was given some old crappy monitor to view them on. Is this actually affecting the quality? If I bought a much better monitor, would the picture be much clearer?
sn00p
  A blue one.
Just fitted a UniFi G3 Pro to the front of the house, very impressed. (As I always am with Ubiquiti equipment). Proper solid unit.
Wife wants one on the back of the house now, I need to get another POE switch now!
