Engine rebuild not going as it should
Car  Clio sport 182
Hi All
Been rebuilding my 04 plate Clio 182 engine and have come across a serious problem, new main crank bearings fitted, new con rod bearings fitted, new valves and headgasket fitted, when i try to turn the engine to TDC with the camshaft tool in place engine wont turn enough to get to TDC, any ideas?
Thanks in advance
Dave
Cams 180 degrees out and pistons touching valves? Wild guess could be miles off
Half moons at the top??? watched three hours of you tube telling me to put the little half moons at the bottom???
Confused .com big time...
so crank was set to tdc, head fitted, cams fitted without moving crank?
Crank was turned through 90Degrees to allow for clearance for Valves, then turned crank to get to TDC but was interfering with valves so stopped and posted on Clio forum.
Head fitted, before tightening cam cover turned crank through 90 Degrees to allow for valve clearance.
Tightened cam cover and then tried to get to TDC , pistons interfering with valves so posted on forum, do the little half moons go on the top or the bottom, if they go to the top i'm going to be very rude to a couple of people on You Tube.
Regards
dave
Regards
dave
I’m afraid they do go at the bottom, so I hope you haven’t been rude to anyone on YT mate!
I can only think you’ve not got the crank pin in the correct position.
[QU
OTE="NorthloopCup, post: 11642349, member: 61663"]I’m afraid they do go at the bottom, so I hope you haven’t been rude to anyone on YT mate!
I can only think you’ve not got the crank pin in the correct position.[/QUOTE]
Morning, all good no nasty replies or messages. I've added some photos to show position of valves when set with special tool and position of crank when aligning pin positioned just in case i'm going mad, looking forward to your replies?
Am i doing something stupid??
Obviously if i were to fit the head the valves are going to clash with the piston at TDC, whats the magic solution?
Is it possible the previous owner fitted different Cams? that's the only thing i can think of.
Thank's in advance
dave
Thank's in advance
dave
Honestly mate, all I can think of is that one of the cams is 360 out as both lots of calves shouldn’t be open that much together.
Surely they can't be 360 out either? Only possible to be 180 out?
This is what I’m trying to get my head around mate as it doesn’t make any sense!
If it was 180 out, the slot for the cam tool would be incorrect.
Crank pins in the right place, slots for the cams is correct......but it doesn’t make sense!
Wrong valves fitted? IE they're too long?
Morning, Compared valves with ones i took out and they bare exactly the same length ETC, Talk about doing my head in????
Even had an experienced Mechanic friend have a look and he's scratching his head as well.
Regards
dave
When you built it back up did you get as far as cam pulleys going On?
Think you might of done what I did once ?
Sorry to be the bearer of bad news but you've bent the valves. Btdt.
Hi
Valves have all been replaced and ground in havn't refitted the head since that's been done, waiting to see if any one has come across this problem before.
Dave
Only thing I can think is if the cam lobes have spun. Pretty sure these are pressed on. Unlike billet cams that are made from 1 piece.
So, glad we cleared that up.little half moons at the bottom.
Has anyone out there got a standard set of 182 cams?
Regards
Dave
