VibraTechnics 172 Gearbox mount fitting
YorkshireKyle
Bought a set of mounts from a member on here but unsure if it’s all there for the gearbox mount. Can see online that there appears to be another part but I don’t have it
This is what I have
A pic I found on the internet
Also, which way does it go? On the Vibra website they don’t have fitting instructions which is helpful
You are missing the spacer which sits under the mount.
I was in the same boat as you, and just substituted a couple of washers, as they don`t ( or didn`t) supply the spacer separately.
Sound. At least it’s nothing ridiculously specific. Been sat here for 5 mins figuring out the b*****d order[emoji23]
I’m sure I have it the correct way now, just the gearbox spider bolt that’s being a turd. Can either of you double check this way is right and I just have to get heavy handed with the dead blow hammer to knock that little s**t in?[emoji23]
