Suspension Diagram - I think I’m missing a bit or two ?
Hello all..
I took my front struts to the mechanic next door and it looks like I’m missing a nut or something...
Can someone add a diagram that’s actually easy to see what each piece is and potentially a part number list too please as the only one I can find on the forum, or anywhere for that matter, is blurry and unreadable
Thanks in advance
Hello all..
Thanks in advance
Not a lot to work with there.
Start here.
https://partsouq.com/
Start here.
Thanks mate, this would be really helpful I found only I knew what the vehicle Type, engine Type, and suffix are. other than F4R I don’t know anything else.
That’s a great website though.
This was also the image I’ve found on the forum yesterday, but I can’t make out the following
- if parts 3, 5 and 6 are washers or nuts
- If part 4 is a rubber bush
My top mount kit looks the same as part 12, however I don’t seem to have part 9
I’ll lay out what I have later and try and work out what it is that I am missing, I’ve not been down the Unit for a while so I’ll get back up to speed and let you all know ?
Having a brief search on that parts site listed above, by winging it ??‍♂️, I believe it’s possibly these that haven’t been ordered or have been lost from my old set.
https://www.renaultpartsdirect.co.u...o-twingo-shock-absorber-top-mount-spacer-nut/
Are they a one time use product?
I’ve got spring platforms, but I’ll be replacing those too.
Here`s the page you want.
No 6 is the top mount bearing.
use CB1N for a 172.
https://partsouq.com/en/catalog/gen...AABfGP4k$&vid=1247&cid=2041882922&uid=3260&q=
You either use the original nut & spacer with an original configuration top mount kit, or use modified kit 543A09780R with No 9.
