Austin-182
At a loss now as to what this can be and it is really frustrating me!
When i bought the car, first attempt to start you get the fast flash red light on the speedo console. 2nd or 3rd attempt and ot would start fine. However, the barrel is also broke and needs replacing as the return spring etc doesnt work.
Anyway, this has got worse, now going from fast flashing light, to a solid light. It will crank but not fire. Then i might try again and it will go back to fast flash and either start next attempt or not start at all.
I had the key tested and 8/10 attempts it read fine so they key guy said he couldnt gaurantee it was a key fault so i didnt get a new one made up.
If i disconect the battery, and then reconect it, it seems to start up fine again!
It can go 4 days without issue then the fast red flash will start up again, sometimes then leading tothe solid light / back to the flashing light.
I know it is difficult to diagnose over the net. But what on earth could it be!?!? Is there a way of finding out or do i literally play roulette with it and work theough a huge list and hope i solve it at the start of the list before i have spent too much!?!?
This in my projectthread but appreciate everyone might not read that.
https://www.cliosport.net/threads/austin’s-clio-dci-100-initiale.824056/
Massive thanks and if anyone has a solutionthat solves it I will send you a beer token!
Thanks
Thanks
