Clio RS Mk2 PH1&PH2
Hi Guy any one have the Clio 172 ph2 ECU pin out diagram?
Thanks
Thanks
Clio 182 Upgraded CPS Loom (Wiring Diagrams - ECU Pinout)
Hi All, Got an issue with my 182 i'm trying to trace, does anyone have a Pinout ECU diagram or Engine Wiring Diagram (would be handy for another job i need to do). Where do the 182 CPS wires go?? would rather test them before pulling the loom apart. do they go straight to ECU if so which...www.cliosport.net
Thanks a Lot.
Thanks I'm have a strange problem with the engine start, I need to check ECU that can be related with that.
Ignition KEY on and cranks for 2 3 turns and then stops dead, if i put the ignition on and wait a few secs before trying to start it will not crank, again, light will not go out. Imo light its off.
I have had the light staying on issue before. There is a small earth ring terminal for the ECU (8mm or 10mm bolt? i can't exactly remember) which can snap off with age. It is located near the left hand side drive shaft cup on the gearbox. Make sure this is attached, this gave me the same issue. However i am sure there is more than one possible cause I thought i'd mention it anyways.
