recalibrate steering angle sensor?
bozothenutter
with the Pure quickrack on the car, does the SAS need recalibrating?
I can imagine that now for a given steeringwheel angle the wheel angle being greater this might wreak havoc with the ABS and ESP....
Sigh...thinking about it...might aswell do it right.
Set wheels @ straight ahead
Remove steeringwheel
Release column (luckily I can reach it from above)
Twist column until SAS shows yellow (is it twist until yellow starts showing plus 180deg?)
Pray everything lines up and refit....
Did you have the wheels aiming forward when you did it to replicate what the sensor is telling the ECU?
The first few times I attempted it, the abs light stayed on after putting it all back together.
Final attempt which worked, all I did differently was I did it with the battery already connected when plugging the sensor back in.
On the attempts which didn't work I had got the battery disconnected as I wasn't keen on having an airbag go off in my face.
I have no idea why that would make a difference, but it did and the light hasn't been on since.
