Clio 182 Wont Start. Engine spins but doesn't crank
Hi all,
When I turn the key in the ignition the engine spins but doesn't crank. I had the car on jacks at the weekend whilst the car was low on fuel and prior to this it was starting. Does any body have any ideas?
- Immobiliser light goes off
- Fuel pump sounds like it's pumping
- Battery is charged
Thanks
Rob
Got it started. Thanks for the reply’s.
Last night I also cleaned the tdc sensor, tried to start it and it didn’t seem to make a difference . This morning before removing the air box again to get at the earth cable I thought I would try the switching around the fuel relay fuses. No signs of corrosion on the three fuses. Tried to start the car again and after a few attempts it fire up.
