Right CS I need some help if possible with some weird PC problems. I've never had any issues with this PC build ever and then all of a sudden I have a couple over the space of a few days.
Firstly, my sound is totally fucked. It keeps popping and crackling, through headphones and speakers too. I've tried different headphones etc and it's all the same. I'm using a Sound BlasterX AE-5 so it's a half decent and newish card. It does the same if I use the onboard too, so I know it's not a sound card issue and I've also tried updating drivers. Also, whenever I watch a video of any sort, could be Youtube, VLC, iPlayer etc, after a few mins the video and audio slowly loose sync and it's dead fustrating. Resetting the video fixes it for 5 mins....
I downloaded Latencymon and it's giving the following -
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
It wasn't that long ago since a fresh install too, but maybe that's the fix?
The other issue is that I have 2 M2 drives, an SSD and 2 HDD's. If I plug both HDD's into the Sata then it shows neither, but if I plug in 1 at a time that shows fine lol. I'll try some different SATA ports for this issue though
