Bleed nipple length
DomP182
  ph1 172, Arctic182
I'm gathering bits to overhaul my calipers but cant find a length for the bleed nipples, from searching on here I've confirmed what I thought from when I last did this that they are M7 x 1mm.
DomP182
  ph1 172, Arctic182
I've been looking at Bigg Red caliper service kits, they are a fair bit cheaper especially for the rears if bought from their Ebay shop and free delivery
MRBILLYUK
  FF Jeden Osiem Dwa
I've got a brand new caliper here , I've just measured my nipple and its 27.6mm long.
I've got stainless nipples in all of my calipers and I'm pretty sure that the threaded part is 1 or 2 mm longer and protrude a tiny bit more out of the caliper, but it doesn't affect them being a little bit longer.
VenomUK
  Clio 172
Big Red are brilliant and top quality parts too. Pleasure dealing with and able to get me the correct parts first time over the phone
Jekyll
I have 2 bleed nipples here. One is stainless, one is normal.
Measurements for the stainless ones are:
And the normal ones are:
Both have a thread pitch of M7 x 1.
I'm pretty sure the stainless ones are too short. I had them fitted but changed them for normal ones as I think they was too short from memory.
MRBILLYUK
  FF Jeden Osiem Dwa
@Dr Jekyll
I can only assume different manufacturers have different lengths.
These are my non stainless nipples. The stainless I'm using are definitely slightly longer.
MRBILLYUK
  FF Jeden Osiem Dwa
I can't copy the link for some reason.
If you type in eBay you should find them. f**k knows why it's come up in big letters lol.
M7X1.00MM HEL PERFORMANCE STAINLESS STEEL BLEED NIPPLES SCREWS HEL1001A
