I'm on my 4th set of PBS fronts and they've always been silent on the road.
Have you still got the anti rattle shims in? You need to remove them if you have.
Ah yeah I do have the shims fitted, thought they needed to be. So I'm guessing removing them will help a lot
Told you they were goodI filed my f3 Mintex down and kept the shims and they're thus far silent and pretty aggressive on the road. Find out Saturday if they're worthy of track use too. Upto now though very impressed having come from cl rc6
How have you bedded them in?
Also, My PBS pads squeal like f**k at low speeds!
Erm a few hundred miles and then a track day round bedford.
Great news ..... guess ear plugs it is!!
I will try that on the way home...... obviously only from 70 -30 mph in a safe environment![]()
I did the above and mine are great. I daily the car and dont have any squealing from the pads.
When I did the bedding in there was a speed van parked up near my mums. I was at the 30 part at the time luckily
Could always plug em up just for the bed in process.I bedded mine in 30mph- 10mph then 70- 30mph x3 and then a couple of 120-30mph
Obviously it was done on track...
But I have massive brake ducts so on the road I cant get the pads hot enough unless I drove like a completely f**k-knuckle
Yeah I thought about it, its finding something that's 100mm and wont fall outCould always plug em up just for the bed in process.![]()
Duct tape.Yeah I thought about it, its finding something that's 100mm and wont fall out![]()
Couple of sponges.Yeah I thought about it, its finding something that's 100mm and wont fall out![]()
Clues in the name...Crude
But it would work![]()
I knew I saw black spots on your 10ft neck!Clues in the name...![]()
Yeah that's what I didI have cooling too, the way to get around it without blocking the ducts is to do the stops one after the other in quick succession.
Got down to 30mph and then belted it back up all the way to motorway speeds and back down again
I had a 1.2 8v in once that needed the brakes cleaning up for MOT. Rather than take the wheels off and stick them on the lathe I just opted to shove 2 ramps under it and I sat at about 50mph holding my left foot on the brakesAlways have to do it at night round here it's that busy.
I might try it on stands next time![]()
After about 15 mins I had to give up because the discs started to glowit's scary though because 1 wrong move and the car is hitting the deck and you're going through the garage doors
Yeah that's what I did with my hand on the handbrakeYeah you have to be a bit careful, but i reckon if you reacted quick enough you could soon stop the wheels with there being no load as such to slow down.
Keep the rear wheels on the deck too, just the fronts in the air.
My dad was too calm for the situationHe said he topped his old Polo out at 110mph on jack stands
Ruthless c**t
Jesus christMy mate bounced his Ph1 off the limiter at like 150mph in 5th on stands
It then started smoking from the engine bay![]()
Clios smoke from the engine bay on idle... From factory
Be worried when they stop smoking![]()
I'll try the 10 stop bedding in process. If that doesnt work I'll bed them in with petrol and a match
