182 turbo oil feed & return
Yarp
  182 Turbo, E46 M3
Can anyone point me in the direction of where to find turbo oil feed and return lines for a clio 182? I’ve seen the engine dynamics ones but I’m not paying £150 for them. Can I use the ones from a 225? If not I’m happy to make them myself if someone can give some ideas on lengths for them
JezzaMac
I bought the pre-made engine dynamics oil feed pipe for convenience and then made my own drain with just 2 threaded barbs, a length of hose and 2 clamps. The drain was less than £15 to do.
I’m sure you get a Cliosport.net discount on the engine dynamics page if you setup a registered account. Just checked - I did get the feed for cheaper than the displayed price on the website, it was £67.15.
Yarp
  182 Turbo, E46 M3
Might just go with that then. That’s a bit better! Did you take the return into the block or tap the sump?
JezzaMac
Tapped it into the block. There is a small flat area just above the sump which is big enough to tap, thread and fit barb.
You can see it in this photo:
daver1985
  172 + 555 scoob
This only cost me about £45 I think or somewhere near
