How easy is it to remove the servo? Mine looks like its on its last legs but haven’t investigated removal/refitting yet!
Got this back from Mick @ Diamond Motors.
Just need some discs and pads for the front and we're good to go for an MOT after 2 years of being off the road!
What was the issue in the end?
Mick said it was just a last bit of air in the abs. He said I'd got it pretty much there with what I'd done but there was just a little bit left. Also swapped the bleed nipples out as the ones in situ I'd knackered. He also told me to replace the discs and pads as they're jiggered from it sitting round for so long. Pedal feels so much better though.
Off the road for 2 years and Mick sorts it in a morning haha. I'm just glad it's been sorted and didn't cost me too much either. I'd like to think I did the hard work and he just got it over the line![]()
You bled it with RSTuner/Clip didn't you?
That should have got it unless you only cycled it a few times.
At least it's sorted now!
That looks lovely.
I bled it with the RS Tuner a few times yeh. Maybe I didn't do it enough, or maybe air was getting in through the knackered bleed nipples as, by the end of it, the fluid had started coming through the threads.
Yeh, I'm just happy it's done now. Sure I've said it before on here somewhere but the thought of me having to get it jacked up, rs tuner hooked up and bleeding it all again several times made me want to jump off a building haha.
Yeah I usually cycle the ABS pump a few times and then go on to the caliper bleeding options.
Makes such a difference to the pedal feel when it's working properly.
It looks good aslong as you don't look under the bonnet![]()
Yeah, it'll be covered now that it's finally working again!Cleaned that many moons ago![]()
Ordered an aluminium replacement Trophy plaque for the side of the drivers seat. Quite happy with it. Looks much cleaner than the old worn sticker.
You do know that you still have the clear cellophane over the original
Yeah, it'll be covered now that it's finally working again!![]()
