Battery drain
DomP182
  ph1 172, Arctic182
I'm still finding my battery drains if left for a few weeks. It's a new bosch S4, I've done a parasitic draw test which highlighted the interior light as the problem so I sorted that but still the problem persists even though a draw test now shows minimal milliamp draw.
Any ideas?
Darren61
I found this happened to me. A few weeks is too long a time to leave it standing and I couldn’t work out if it was my car or just a Clio thing in general.
Opted for a trickle charger/battery conditioner to plug it in when not in use and it’s been fine since.
Could be worth a look?
DomP182
  ph1 172, Arctic182
I could do but I'd love it to just work as it should, doesnt help that I'm not exactly clued up with electrics
TheEvilGiraffe
South East - Essex
A few weeks ?!
The alarm will be working.. might not be using much but multiply that over a months worth.....
If it's dying in a week or less, I'd say it's worth investigating. 2/3/4 weeks ?!
Trickle charger as above.
I have a NoCo one.. does the job. Plenty to choose from - find one that suits your application.
DomP182
  ph1 172, Arctic182
A few weeks ?!
What is the normal acceptable amp draw for a 1*2?
DomP182
  ph1 172, Arctic182
No, sorry I meant how many milliamps do you measure - 10, 100, 1000?
Oh crap sorry, I forget now but pretty sure it was sub 10mA but it must be killing my battery somehow. Would the alternator drawing back require testing in a different way?
DomP182
  ph1 172, Arctic182
Out of interest for the last week or so I've left it unlocked and it's starting where as it would normally be pretty flat by now. Could it be the alarm causing the drain once armed and how do I check that?
obcuz
I've bought several of those Bosh S4's, when one car went to the body shop with brand new S4 on board, after some months, it returned and the battery was completely buggered, probably left in a discharged state for some or all of that time (I guess).
They are guaranteed 4 years, so take to local garage and ask for a load test on the battery to be sure it's not duff?
DomP182
  ph1 172, Arctic182
I bought it from ECP so exchange shouldn't be too hard hopefully
Flob
Yes absolutely. This happened on a colleges Porsche and was quite difficult to trace. In the end I hooked up a rasberry pi and datalogged the current consumption over night but it would be just as easy to hook a multimeter up and carefully close the bonnet over the probe wires.
A battery of your size should manage 3.5amps for 20 hours, so 200 hours at 350mA (3 days), at 10mA your looking at over 290 days (ignoring self discharge).
So your current draw is either substantially over 10mA or your battery is shagged.
Rob,
obcuz
I bought mine online from ECP and they exchanged it no problem, as long as you got your receipt, the guy didn't even check it, but wouldn't count on that, as said just get a load test done.
DomP182
  ph1 172, Arctic182
Rob,
So if I connect my meter up in series with the battery, shut the bonnet and lock is to test the draw with the alarm set I should get a true result. I'll post my findings if this is correct
Flob
Yes boss. Worth leaving it for 10-30mins and checking it across that time. The Porsche needing an interior sensor of some sort however the current draw didn't go up the moment the alarm was set.
DomP182
  ph1 172, Arctic182
Cheers mate I'll give it a go
Flob
My BMW battery only lasts 2-3weeks without being driven and I just bought a small solar panel which I leave in there while not using the car and the issue never happened again.
DomP182
  ph1 172, Arctic182
Still not done this but I have found the photo on my phone if the result last time, it was 13 milliamps. Today after retrofitting cruise control and road testing it all I've found that manually turning the headlights on dips the revs significantly to the point that stationary main beam will cause a stall.
Mr Trailer Man
As I mentioned earlier in the thread, 13mA is f**k all really.
But it does sound like your alternator is dead if it's cutting out whilst turning lights on.... Maybe it's not been charging the battery after all, and that's why your battery keeps dying?
DomP182
  ph1 172, Arctic182
I Agree, I think it must be. The only reason I'd ignored that idea was because with the engine running I get 14.something volts so thought it was fine. Any other tests i can do on it?
DomP182
  ph1 172, Arctic182
Could get it drop tested.
Not sure how/if you can do it with a multimeter...
Today seemed like a good day to stand out in the cold testing the parasitic drain, so I connected my multimeter inline with the battery before opening the passenger door, heres what I found.
The fuse on the mA setting has blown so used Amps and straight away I was getting 0.08Amps (80 milliamps? )
Opened the passenger door and this went up to in the region of 0.12A so I clamped the door interior light switch assuming when iyhe light faded down the Amps would follow drop back to 0.08A but they didnt?
At this point I began pulling fuses, all fine except this fuse which I think is related to the interior lights or alarm sensors? This brought it down to 0.011Amps.
Flob
120mA is still low, higher than you would like but still not a huge deal in the scheme of things.
to put this into perspective. If you had a 1Ah battery, it would be able to supply 120mA for 8.3 hours.... You likely have something like a 40Ah battery so with 120mA drain your at 300+ hours.
If your engine stalls when lights are on your alternator is either duff or more likely your battery. A good test is to (with ignition on and engine off) measure the volts at battery (after you've been for a drive), then turn every light on (inc high beam) and measure the volts at the battery again. Simple test, let us know what you find.
DomP182
  ph1 172, Arctic182
I've just fitted a brand new Renault alternator as the last one began smoking. I dont use it much so 120mA is enough to mean its flat when I come to.
Definitely something up with something running off that fuse
Mr Trailer Man
Is it maybe a case of the power taking a while to shut down on that circuit? Modern cars can be like that.
Like on my 182 I noticed I can still open the windows if I press the switch just after I've turned the key off.
Flob
Your engine should 1000% not be stalling so easily with the high beam on. Same happened to my alternator couple of weeks ago (seems really common at the moment!) the smoke is it becoming a hard short across your battery which will have done it no good. Try the poor mans load test above and see how much the battery volts fall by.
Flob
Yes could well be. Could also be the part of the keep alive cct. with the radio or alarm has failed (often an old capacitor etc). You could try unplugging the radio to see if it falls.
If it were mine I and I left it for weeks without driving I would just install an isolator switch by the battery.
DomP182
  ph1 172, Arctic182
Theres no stalling problems, it runs fine when I drive it, its sorn at the moment though.
I have thought about an isolator but I just want it to work as it should, I'll try your idea tomorrow Rob.
Flob
Was this before you changed the alternator Dom?
DomP182
  ph1 172, Arctic182
Oh yes! That was a used alternator I fitted which promptly started to smoke so shelled out £182 to Renault Wolverhampton for a shiney one
