I will be carrying out a abs delete on my track car , what brake bias valve would people recommend who have done this on there track cars as i see there afew differnent options available.
Also this is my master cylinder which came with the car , any ideas which one this is , stamped ate , 90 fittings to a t piece be best for my line to the bulkhead ?
AP Racing or Tilton are the only ones I have tested which give enough pressure reduction, the Wilwood ones may also work but never tested. Stay away from the like of Compbrake or anything non branded from eBay etc.
Alot of ABS delete kits are just a s**t load of braided lines to run all over the place.
IMO thats not the best way to do it, ideally you want all solid lines with just the normal braided line to the caliper.
Get a load of Kunifer pipe and a decent flaring tool, make your own up.
