Seats with R022 cage
Car  BMW 120D M Sport
Hello everyone,
can i ask anyone thats got a safety devices R022 cage fitted what seats your are running?
I bought a seat and it physically will not fit! 😤 im fuming as i looked into seats and thought this would fit before i purchased it.
iI don’t want to go buying another seat and having the same issues so would like to know what seats people have managed to fit in with this particular cage please!
thanks in advance
OMP HTE R fitted in mine. You can get the dimensions online to see how compares to your seat. Where is it hitting the cage? It is a bit close on the door bars but workable
I didn’t get any photos of it in the car but it was touching the door bar.. there is no way i could squeeze it in! So frustrated but i should of measured properly before hand 🤷🏼‍♂️
Jon Foz... i think if i managed to move it over enough the centre of the seat would be well offset to the steering wheel and would just feel odd.
I’ve put the seat up for sale anyway and going to research properly before buying another, Just wanted to see what other seats people have fitted with this particular cage
Have a look at @Hyperhatch project, he was the first person on here to have this cage fitted
Why would it be offset to the steering wheel? The wheel by standard is a mile to the left. Why dont you weld in seat mounts?
I’ve got Cobra Suzuka on the drivers side on a John Foz seat base. No fitting issues at all. The seat has always been comfortable. I’d recommend one
I think it would be ideally the seat would need moving over a good couple of inches, I cant really be welding in seat mounts now due to having the inside of the car painted
I had to go back to an OMP seat base after having the R022 cage fitted as my seat wouldn't fit with a Jon Foz base. I've got a custom made Motordrive seat which isn't the smallest, it fits in fine now but it gave all sorts of issues to begin with.
As mentioned above I've had to drill extra holes in the seat base to get things to line up, and run a length of ali box section on the inside to level the seat base, not ideal but it works
Found this if it helps, the seat has been brought forward slightly but its in and clears the door bar even with fia cage padding on it
I had a mirco rts seat at first and then found out that their known for a wide fit and wouldnt fit with door bars. Even with extra holes drilled in the jon foz frames
Then changed to motordrive seat which was narrower and a better fit, although still tight and still not 100% centre but miles better than before
I also ditched sparco side mounts as they were angled in and tight for the seat to slot in, now got side mounts that are straight from the base up. Sabelt ones
Was just one of that jobs that I didnt expect to have so much hassles with after trying several things gradually over the last year or so to improve it each time
I found the same with an RO17 cage and an OMP seat. I managed to just squeeze it in but only after a lot of swearing and shouting.
